Hi All, So ive currently got dual wan using pfsense in which im always getting the Following when trying to access online banking (Santander)
This site can’t provide a secure connection
retail.santander.co.uk sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
Ive searched google and found multiple attempts to fix it but would then limit the speed on other stuff as its limiting all SSL connections to 1 of the WANs.
The Load Balance is set to both Tier 1 and other than the banking sites everything works fine. Can anyone maybe recommend a set up?
Ive considered looking into maybe setting a firewall rule to force all banking connections through a Tier 1 / Tier 2 Load Balancing but its getting the list of either IPs or domain names / hosts for that to be functional
