Hello everyone. i would like to know if someone can help me on this topic.
Limit bandwidth is ease set on pfsense but is it possible to add some quota traffic as well, I mean when one IP or client reach a define monthly or daily amount of total data (up+down) it will be throttling down to specific bandwidth.
example: Bandwidth up and down both 5 Mbts/s then when you reach 100GB the bandwidth will be thottling to 1Mbts/S.
Thanks in advance.
As far as I know the only way to do this would be via captive portal.
Hello. thanks for the respond. so if i use captive portal whats should be the configuration for. please help me.
On other forum they said to use Raid what do you think. Iām new on that domain
Not sure how Raid relates at all, but here is the documentation for pfsense Captive Portal.
https://docs.netgate.com/pfsense/en/latest/captiveportal/captive-portal-configuration.html
I will check it. if you have any advice let me know.
sorry i make mistake. I mean Radius.
Yes, you can tie the captive portal to the radius server in pfsense and set the quotas there.
Do you have any video which can help me for that? ![]()
