I’ll try to lay this out as concisely as I can, but I’m baffled by an odd issue (or a misunderstanding) with an IPsec setup I am working on in my lab.
The VPN is connected and working and I’ve done a ton of troubleshooting already with no luck. Below is the layout, then I’ll explain what’s not working.
- Site A
- Local subnet of 10.10.12.0/24 with a host at 10.10.12.10 which I am using for testing
- IPsec Phase 2 setup to connect to Site B
- Network NAT enabled on the Phase 2 to NAT to subnet 172.16.51.0/24
- Firewall rules on the 10.10.12.0/24 subnet to allow pinging to a 192.168.15.0/24 subnet at Site B
- Firewall rules on the IPsec tab to allow 192.168.15.0/24 to ping back to 10.10.12.0/24 (since NAT is processed first, as documentation talks about)
- Site B
- Local subnet of 192.168.15.0/24 with a host at 192.168.15.10 for testing
- IPsec Phase 2 setup back to Site A
- No NAT enabled
- Phase 2 is setup with the Remote Network as Site A’s NAT subnet
- Firewall rules on the 192.168.15.0/24 subnet to allow pinging back to 172.16.51.0/24
- Firewall rules on the IPsec tab to allow 172.16.51.0/24 to ping 192.168.15.0/24
The issue I am having is that 192.168.15.10 at Site B can not ping 172.16.51.10 (which translates to 10.10.12.10) at Site A. However, Site A’s 10.10.12.10 can ping 192.168.15.10 without issue. More importantly, if Site A pings Site B first, then Site B can ping back to Site A just fine.
As I understand it, this should be working according to documentation since each 4th Octet is NATed at a 1 to 1 ratio, so Site B should be able to initiate pings.
192.168.15.10’s traffic does pass firewall rules and does pass on both the IPsec tab (validated with a pcap) and on the “WAN” (quotes since this is a lab) based on the ESP packets I am seeing (no other VPN in use and the counts match).
The traffic gets to Site A as well, validated also by checking ESP packet counts. But it never shows up on the IPsec tab with a pcap. And the Security Associations on IPsec > Status don’t count bytes up, so as I understand it this is failing the SPD check.
But if I check the IPsec SPD tab, I can see a proper SPD entry for 192.168.15.0/24 > 172.16.51.0/24, so as I understand it, it should work. I can’t find info on it, but, isn’t the SPD checked before NAT would happen?
Regardless, I feel like this should be working and I’m pretty lost here.
