I’m getting 90+% cpu usage and about 82-84% coming from the item listed below:
/usr/local/sbin/unbound-control -c /var/unbound/unbound.conf stats_noreset
Running 22.05.
Any way to cut this back?
Running 22.05.
what other packages do you have installed?
what version of pfsense?
What spec of machine are you running PFSense on,
pfsense + 22.05 on a Netgate 3100
Packages:
I believe there is a known issue of high CPU usage with 22.05 and pfblockerNG-devel. I can’t remember the details, but I vaguely recall something about an available patch. Check the pfblockerNG section on the Netgate forums.
