I have never tested this with Proxmox but nake sure you are using HTTPS when accessing HAProxy, make sure for the back end is pointing at the right port number and and both Encrypt(SSL)SSL checks are checked
The first video was the one I was referencing. I do hope the latter will help me. And yes I am sure that I point to the proxmox server with the rigth port.
It did!
It seems like I don’t get an certificate…
CONNECTED(00000003)
407786BBE47F0000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../ssl/record/ssl3_record.c:354:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 5 bytes and written 315 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
Now to figure out why this is happning… by watching the first vid again.
