Hi!
First at all I watch your videos now for some month an i really love it. It is really useful and well done.
I just want to know if there would be a solution for my prob:
Before I start I need to tell a bit about my network >> For my Network I used pfSense since the beginning (before I used the m0n0wall ;)).
I came in touch with ubnt because I had some nice 2,4Ghz and 5Ghz routs between 800 m and 12 km (over a mountain 1200 m high). I used Airgrids,… Then I tried the Unifi Wlan, Cloud key,… and I loved it. Last but not least I received the USG-XG-8 (because I have a 10G network) and my first impressions was very nice. But after playing around a bit I found out that the USG is not really a clever replacement for my pfSense. So may options are beta or not onboard os far. ;(
After whating hours and hours of your pfSense Videos I am back to pfsense. I want to build a pfsense HA system (2x HPE DL360 with 24 GB Ram SSDs an 2x10G LAN +4x1G). So far so good.
But iam really sad putting my USG-XG-8 to the shelf without any function. So now comes my question:
Do you see reasonable configuration where I can use the USG-XG-8 behind the pfsense HA?.
Thanks for your help. Greetings from Austria
