Hi everyone,
I followed Tom’s video to setup OpenVPN on pfSense for remote access. Everything went fine and I can connect from the outside. But there’s a problem with resolving some DNS entries.
I have some services (e.g. Paperless-Ngx) running on my local network only and not exposed to the internet. They are running behind a Traefik Reverse Proxy as Docker Containers. My local domain is singularity.lan but I had Traefik generate proper Let’s Encrypt Certificates for my services. In the case of paperless the certificate’s CN is paperless.singularity-home.ch. So to reach the services I added Host Overrides that resolve to the IP of the server that is running Traefik.
It all works perfect when connected on the local network, but when I am connected with an OpenVPN Client from the outside the DNS entries I added in the Host Overrides Section of the DNS Resolver are not resolved. I can ping all machines by IP but not by DNS name.
Here’s the output of ping and dig for that DNS name when connected via VPN:
ping paperless.singularity-home.ch
ping: cannot resolve paperless.singularity-home.ch: Unknown host`
dig paperless.singularity-home.ch
; <<>> DiG 9.10.6 <<>> paperless.singularity-home.ch
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 61034
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 1, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1432
;; QUESTION SECTION:
;paperless.singularity-home.ch. IN A
;; ANSWER SECTION:
paperless.singularity-home.ch. 14400 IN CNAME singularity-home.ch.
;; AUTHORITY SECTION:
singularity-home.ch. 3500 IN SOA ns41.infomaniak.com. hostmaster.infomaniak.ch. 2024091305 10800 3600 605800 3600
;; Query time: 80 msec
;; SERVER: 10.20.20.1#53(10.20.20.1)
;; WHEN: Sat Sep 14 13:58:41 CEST 2024
;; MSG SIZE rcvd: 149
I added an ACL to the DNS Resolver to allow queries from the tunnel network, but it still doesn’t work. I am running this on a Netgate 1100 device with pfSense+ 24.03.
Has anyone else had this problem? I’m kinda stuck and don’t know where to look for clues
