Hello everyone,
I’m new to Ubiquiti and decided to give it a try.
I already have a pfSense setup with rules in place, but no VLANs. Since I’m upgrading to a better switch, I figured this would be a good time to implement them.
Current setup:
WAN from ISP router → pfSense
pfSense LAN: 192.168.88.254/24 (no VLANs)
What I want to implement:
Two VLANs:
VLAN 40 → Guests
VLAN 50 → IoT / Management
pfSense connected to switch on Port 1
Cloud Key on Port 2
APs on Ports 40–48
Two SSIDs: internal + guest
I have this working at a basic level, but I want to refine it—especially VLAN 50.
My goal is for the switch, Cloud Key, APs, and future devices like CCTV to all reside in VLAN 50.
However, when I set the switch’s native VLAN to 50, all other devices on the network lose access to the switch UI.
How can i set this up?
Leave VLAN 1 just for the APs, Switch, CloudKey and PfSense on 192.168.88.0 and then create a new vlan called “Internal” or something like that and assign all the other ports (Port 3 - 40) to said VLAN? AKA use the VLAN 1 as the MGMT vlan of sorts?
