I am having a strange issue on my laptop. When I am connected to my work Wifi with pfsense as firewall. Spotify open and shuts instantly. When I teather to my 4G network it works fine. When I openVPN into the office wifi spotify works fine. I have a clean Win 10 vm on the same server host as pfSense. Spotify opens and closes on that too. The only firewall we have on the network is pfSense.
I have had snort installed on pfSense but have removed it.
I have the following rules enabled on the firewall.
I dont believe so. I set it up and used the defaults. Even with it disabled it is still the same. I have just checked with others in our office and they have the same issue when connected to wifi.
If I’ve read the thread and responses correctly my suggestion is to attach at work thru a RJ-45 connection - thereby bypassing the WIFI. In all the examples the WIFI seems to be a common access point and might be the problem.
