PFSense - Block websites for kids on their home network VLAN
I am using PFSense at home as well as a Unifi wireless access point.
I have a separate WiFi network with its own VLAN that my kids connect to with their laptops.
On PFSense I’m using pfBlockerNG to block bad sites for the entire network.
I want to be able to block certain websites just for their VLAN (youtube and a gaming site) during the week and then open them back up on the weekends. But I only want it to be blocked on their VLAN. I would still like to be able to use Youtube on the network my wife and I use during the week.
I asked on the PFSense forum about it, but I don’t understand how to do what their response told me.
I see where the documentation for PFSense talks about blocking websites, but as far as I can tell its just for blocking everything and not just one specific VLAN
https://docs.netgate.com/pfsense/en/latest/recipes/block-websites.html
Any pointers on how I can do this please?
Thank you for any help
Jason
You’ll need to dig a lot deeper, but you can install e2guardian and apply it to specific vlans. I don’t think you can have time schedules though. You may need to set up a computer to work as proxy where you can schedule a task to make it active or bypass.
Because pfblocker is a DNS blocker you have to configure your DNS settings to tell it to bypass or use dnsbl on the subnet you want.
Navigate to Services>DNS Resolver>General Settings and add the example below in the Custom Options section.
Example:
server:
    access-control-view: 192.168.2.3/32 bypass
    access-control-view: 192.168.2.0/24 dnsbl
    access-control-view: 192.168.1.0/24 dnsbl
view:
    view-first: yes
view:
    view-first: yes
server:include: /var/unbound/pfb_dnsbl.*conf
You could always use openDNS for the DNS for their VLAN only and then do the filtering through your openDNS account. That’s what I did when my kids were little and it worked quite well. It used to be free too. Maybe it still is.
