Hi !, I’m switching over from a sonicwall NSA 4600 to pfsense and thanks to the many videos on here I was ablt to get most of it running, the only issue I am having is getting openvpn clients to be able to get access to my lan ressources and people on my lan to be able to contact the open vpn clients
So far, i’m able to connect but not access the lan ressources
I’ve got it working if I add a gateway to my pfsense lan adress (using 10.1.1.1) which is my layer 3 nexus
as of this moment nothing is using 10.1.1.1 as their gateway
The way my network is setup is that
My pfsense server is 10.1.1.3/16
all my lan switches are in the 10.1.1.0 subnet with mask 255.255.0.0 and their gateway is pointing at 10.1.1.3
all my servers are in the 10.1.0.0 subnet and mask 255.255.0.0 and their gateway is pointing at 10.1.1.3
my printers are in the 10.1.4.0 subnet mask 255.255.0.0 and their gateway is pointing at 10.1.1.3
on the openvpn server settings
the ipv4 tunnel network is 10.1.5.0/24 I tried going 10.1.5.0/16 and it would fail to give me an ip adress from the openvpn server
my ipv4 local network(s) is 10.1.0.0/16 (which I think should give me access to all my subnets)
as i stated previously, if I don’t add a gateway on my pfsense lan adress (10.1.1.1) which is a layer 3 cisco switch I can’t connect to my lan ressources from the vpn
I also tried adding a static route for the 10.1.5.0/24 segment pointing to my pfsense server so my lan behind the fpsense could communicate to my openvpn
Anyone could nudge me in the right direction ?
