Hello everybody,
I’m trying to figure out my network configuration with my pfsense 7100. In the 7100s UI there is a place to configure the switch that is built into the machine. I would like to make it so that only specific VLANs go over specific ports. I tried it on the physical machine and the layer 3 switch it’s plugged into started throwing STP errors.
In order to figure this out I generally like to use GNS3 to test everything before I put it out. I haven’t found the budget to buy two of everything. I have a project setup with a virtualized pfsense instance with a couple of vlans going to different clients. However it doesn’t seem to have the features of the 7100 where it manages a switch or a group of interfaces like a switch. Has anyone managed to do this before?
I tried digging through the 7100s system to see what its doing but all I can seem to find is it looks like it sets up a LAGG for each VLAN, including WAN and LAN. So I presume if I could recreate it that way? I tried searching through the file system but I cannot figure out where the config for the interfaces is actually stored. Which makes me think it’s generated on the fly when the config.xml changes.
Anybody got any ideas?
Thanks!
