Hello Everyone,
With this work from home fiasco, I have a company that is going to downsize their office and work from home mostly. Currently, they have a hosted PBX through Windstream (trashhh) and I am switching them over to 3CX.
Right now I am having a few issues with what is definitely (I think
) being caused by the Pfsense router. I have the correct ports forwarded according to the site, I’m able to connect phones/apps. I attached a drawing so you can see what the problem is and why I believe its something in PFsense.
I am not a 3CX user, but they have their documentation here https://www.3cx.com/docs/manual/firewall-router-configuration/
And pfsense has some here regarding VOIP, but I have not had to use any of it with pfsense.
https://docs.netgate.com/pfsense/en/latest/nat/configuring-nat-for-voip-phones.html
A guess would be that you need static outbound NAT rules, but that is just a guess.
Thanks @LTS_Tom. ah yes i have seen both those documents. This is the one I mainly followed and it has worked for the most part just this annoying audio issue only with the phone app. I just attached pictures of the nat and ports…I believe it is setup correctly
Mine is on Manual Outbound NAT and mobile client works perfectly. Although i use Asterisk box and not 3CX but i am assuming it would work in similar way. Finetuning it with pfSense might take a while but its rock solid stable.
I was actually able to get it to work by splitting all the ports up instead of doing TCP/UDP on 5060 5061
