Pfblocker NG (IP Block Stats)
Hi Everyone,
My name is Darius but you can call me D for short. I’m new to this forum and I was seeking for some help or advice. I currently have pfsense CE for my home and it was working great until like the last three weeks. I keep having an issue with pfblocker NG and I can’t see the IP block stats page. I’ve read countless blogs or posts relating to this issues and it still persist. Things like restarting the pfblockerNG firewall filter service, reinstalling pfblocker NG, uninstalling pfblocker NG and installing it again. I tried installing the dev version. I even went to the full extent of wiping the drive and installing pfsense from scratch and the issue still remains. Any help or advice relate to this issue. It was working fine before. I’ve uploaded screenshots. Please and thanks.
Welcome to the forums,
Do you have
  • block lists setup under pfBlockerNG → IP → iPv4 & logging enabled?
  • A public IP ?
  • pfblocker endabed?
Hi Tom. Hope all is well. I’ve checked everything you listed on the earlier post. Everything seems to be setup the correct way. I was trying to see if I could find logs associated with the issue to pinpoint the issue. Unfortunately I can’t get no data on that either.
Not sure what is wrong, I don’t really use pfblocker for anything other than inbound connections anymore. You might want to post in the Netgate Forums as well https://forum.netgate.com/
Hi Tom,
I’m so I’m building my pfsense all over again which is fine by me but I’m keep getting error like the server is busy and I can’t access the web page. Am I getting DoS and it preventing from accessing the page
In addition I get this error when trying to update geo IPs in pfblockerNG
Uploading: IMG_0005.jpeg…
uninstall pfblocker and make sure pfsense is working correctly. Don’t worry about pfblocker until you get pfsense working properly.
Hi Jimmy,
I have had experience with pfsense for about two years now. I believe to think I know how to set it up. In addition Tom has a tutorial on YouTube on how to setup pfsense. When in doubt I definitely watch it. I’ve watch so much I almost know it verbatim. It’s some else going on. Like I mentioned before it was working fine before. Please and thanks
This is the link to the setup: https://youtu.be/fsdm5uc_LsU
