I have been beating my head on a problem that I encountered while moving things from one subnet / VLAN to another.
I have six VLANS set up on my network:
VLAN 1 192.168.1.0/24 Not generally used
VLAN 5 192.168.5.0/24 Guest
VLAN 10 192.168.10.0/24 Tv stuff
VLAN 15 192.168.15.0/24 Experimental
VLAN 100 192.168.100.0/24 General
VLAN 1101 192.168.200.0/24 Admin
The 5, 10,15, 100 VLANs are set up with separate SSIDs on my wireless access point as well as several wired connections to computers and things around the house.
The network is
Pfsense router ← Trunk 1,5,10,15,100,1101→ Zyxel GS1900-24 switch ← Trunk 1,5,10,15,100,1101 → TP Link EAP245 Access point.
The problem I am having is trying to connect my Pixel 5a and Fire tablet to VLAN 10. They are failing to get an IP address. I can connect to that wireless network with my laptop and it works fine. I can connect the phone and tablet to the network by using a static IP. The phone and tablet both connect to VLAN 5 or VLAN 15 flawlessly.
I have compared the setup on the DHCP servers for each of the VLANs, looked at the setup of the trunked links to both the router and access point with no success.
I also set up a second access point and added the offending VLAN and one of the usable ones with the same result.
Does anyone here have any ideas on what other steps I can take short of rebuilding the PFSense configuratin or Switch config from scratch?
This is what shows up in the DHCP log when a failed connection occurs.
| Jan 17 15:07:36 | dhcpd | 65713 | DHCPOFFER on 192.168.100.154 to a2:7e:0c:cb:6e:4c (Pixel-5a) via lagg0.100 |
| Jan 17 15:07:36 | dhcpd | 65713 | DHCPDISCOVER from a2:7e:0c:cb:6e:4c (Pixel-5a) via lagg0.100 |
| Jan 17 15:07:36 | dhcpd | 65713 | DHCPOFFER on 192.168.10.113 to a2:7e:0c:cb:6e:4c (Pixel-5a) via lagg0.10 |
| Jan 17 15:07:36 | dhcpd | 65713 | DHCPDISCOVER from a2:7e:0c:cb:6e:4c (Pixel-5a) via lagg0.10 |
Sorry if this post is too long but I wanted to include the pertinent info and let everyone know what steps have been taken.
Thanks for your help
Ken
