I have 2x 10GbE FreeNAS machines which perform poorly if the speeds others get are accurate
(and I assume they are).
To test transfer speeds on the unit which doesn’t yet have data,
I striped 7x 6TB 7200 rpm 100MB/s (System 1, below: MacPro 3,1)
I have however, transferred data between my Windows machine and my MacBook Pro (ATTO 10GbE to Thunderbolt – ThunderLink) and was able to obtain over 400MB/s transfering to and from NVMe drives.
I just can NOT figure out how to make FreeNAS generate much throughput.
I’m considering just booting the MacPro in to OS X and setting it up in a striped array to test the performance via OS X … to troubleshoot some of the hardware or software that way…
Any help would be appreciated. If you’d like me to provide info, can you please make it easy for me to understand which information you’d like…? Ideally, request a screenshot and define exactly where I’d go to provide said screenshot.
CONFIGURATION:
NETWORKING:
• SWITCH 1: D Link DXS-1210-12SC 10GbE Switch SFP+
• SWITCH 2: Airport Extreme + AP Express extender
WiFi via Airport + Extender
SMB sharing
10GbE via SFP+ Fiber
MacPro3,1 Dual Xeon CPU
• 2x 2.8 GHz - Quad Xeon (X5482)
• 16GB ECC RAM
• 7x HGST Ultrastar 6TB SAS 7200 rpm
• LSI 9211-8i SAS controller
• 10GbE SFP+ Network card (shows connected in FreeNAS)
• TrueNAS core 12.0 Beta
LESS THAN 100 MB/s … even with 7x striped drives with no data. -
Dell PowerEdge T320 (single CPU)
• FreeNAS Version: 11.3-U2.1
• E5-2403 0 @ 1.80GHz
• 48GB DDR3 ECC RAM
• 10 GbE SFP+
• SMB Sharing
• 8x 10TB HGST IBM Ultrastar SAS 7200 rpm
• RAIDZ 2
• Fastest transfer speeds up to 180 MB/s
Does this sound correct…?
IN ORDER TO PROVIDE ANY REQUESTED INFO, PLEASE STATE SCREENSHOTS TO ATTACH
THANK YOU!!! ![]()
