@LTS_Tom & community
I’d like to script backing up the unifi autobackup.unf files found in
/var/lib/unifi/backup/autoback
from my controller PC (Ubuntu 16.04.5 LTS) to my desktop PC (Kubuntu 18.04) that are both on the same network and run the script in CRON.
There are a couple of issues:
- /var/lib/unifi/backup/autoback is owned by root
- I use id_rsa for ssh with password. I’d like to have the script run daily in CRON so I need to automate login, but don’t know how to or best practice to accomplish this.
Here’s what I can do at this point:
- script on controller running daily in CRON copies the most recent backup to a directory in $HOME && chown to me
- manually rsync controller $HOME/dir with desktop $HOME/dir (manually enter id_rsa passwd)
The ultimate goal would be direct sync with CRON running on Desktop, but if I can accomplish #2 above and run a CRON on both systems, that would be OK.
I appreciate any suggestions; I have no experience automating logins. I definitely do not want to hard code in a password.
Thanks
First, setup SSH keys so you don’t need to use interactive passwords, second you can use rsync to script the backup like this in a cron job:
rsync -avrhiO --no-perms --delete --progress --stats /var/lib/unifi/backup/autobackup/ -e ssh backupfiles@SomServer:/unifi/Backup/Loaction/
Thanks for the help Tom! Here is what I ran (as -n [–dry-run]) and the result
rsync -n -avrhiO --no-perms --delete --progress --stats -e ssh
me@192.168.x.y:/var/lib/unifi/backup/autobackup/ $HOME/Desktop/unf_test
receiving incremental file list
rsync: change_dir "/var/lib/unifi/backup/autobackup" failed: Permission denied (13)
no pass on id_rsa gets me into controller, but I get a permissions error while trying to tinker with:
Btw, I’m trying to pull from controller (rsync source) to Desktop (rsync target), hence the change to rsync line.
Not sure how to get around the permissions error except to first run a sudo CRON on controller that copies .unf to my $HOME on controller with chown to me. Currently doing that. Root owns those files in /var
Is there another/ better way?
It works perfectly when use source as $HOME/autobackups/ that had previously been copied from /var and permissions set.
You appear to have “-e ssh” in the wrong place. Make it like mine
Also, you can use this https://crontab-generator.org/ to help with editing the crontab -e
Thanks Tom. Magic sauce is:
- create new id_rsa sans passwd on controller as ROOT.
- ssh-copy-id root id_rsap.pub to target PC
- edit crontab as root and use your command format or script
I chose to put the command in a script and call script in cron.
I just spent hours to save minutes! But I LEARNED new things.
Thank you.
