What is it?
I fight with DNS settings as along with my ISP servers also Cloudflare is permanently involved.
I didn’t set Cloudflare and I dont want it. DNS setting is on AUTO
What is it?
I’m not entirely sure what you are talking about. Can you go more into detail about your setup?
I just want to know what is option 60. It is enabled since I initiated the router (UDR7) and everything is working fine. Well except the unwanted Cloudflare DNS servers.
The Ubiquiti AI don’t know what option 60 is ![]()
Option 60 is the vendor class identifier (VCI). Some ISPs require it for DHCP. Has nothing to do with DNS.
I don’t know of such a thing in DNS, however there is a DHCP Option 60. It’s set on a client device to tell a server about the type of equipment it is.
I don’t think it will have anything to do with using Cloudflare DNS unless you set a specific pool of DHCP-assigned IP addresses to use different settings based on the vendor identifier.
Unrelated. You can send DNS settings to a client via DHCP, though. The way you have it set, the DHCP server will automatically choose the DNS settings to send. I bet if you hover your mouse over that “i” in the circle next to it, you’ll get more information.
