OpenVPN on UniFi vs pfSense
I have two offices that need remote access with MFA. One office has a UDM Pro and the other has a Netgate 6100. Both devices work for remote access. The problem I am having is that they behave a little differently when someone forgets to disconnect their VPN client.
The Netgate device will attempt to reconnect a couple times then give up. No problem there.
The UDM Pro will keep trying to reconnect the client until the user gets locked out in Duo.
I have compared the client config files for both sites and can’t see any differences that should cause this behavior. Not sure I can see the server side config on the UDM to check for differences there. Does anyone here have any experience or thoughts on this issue.
Thanks in advance.
