paulnye about 8 hours ago
I setup OpenVPN server, did the client export for windows, and was successfully able to connect from the client. I used this video as a reference - Tutorial: pfsense OpenVPN Configuration For Remote Users 2020 - YouTube
However I am not able to ping devices on the LAN
Here is the route print info…
Thanks Tom. Solved it, and now I can ping LAN IPs and do RDP etc. It was the devices on my LAN were not using the pfsense IP as their gateway, but a different gateway device. I didnt think all the target devices on the inside of the network needed the pfsence box as their gateway. It makes sence now.
Also, a gateway IP is still not present for the openVPN connection, but connection to LAN devices and to the internet is working normally despite this.
