Just wondering if you need more than one appliance or just one to do it all.
I’m consider one of the netgate sg-5100 as it have some more power vs the 3100 and to support the project pfSense.
But can I have one it do it all? Connect the ISP modem directly to it and then have it do:
firewall,Smart QoS, Suricata, squid, squidguard, Openvpn, router.
And then just add a Ubiquiti nanoHD AC for WiFi to one of the Ethernet port and some more items like fire TV cube to the other Ethernet and a switch to connect even more
Yes it can but I would put pfsense on a more powerful box. For price vs performance, I would use a used server like Dell r210ii because netgate devices are not very powerful if you enable all those features. Your thoughput will suffer.
In that case do you know of a smaller footprint box like a protectli or qotom. It seem they are a bit more $ than the r210 but I would prefer something small.
Protectli top Box have a i5-7200U dual core.
Do Suricata benefit from more cores?
Also found another box with a 6 core i7 8700T
But say 2 Lan ports.
Can you alway configure them in pfSense to be WAN and LAN or it depends on the actual hardware configuration?
If you have the money for the sg-5100 go for it. If cpu benchmark scores are comparable for Suricata, I’m guessing you’ll be able to get about 500 Mbps throughput. So if you have a faster WAN connection you’ll either need to with a higher end Netgate appliance or get something with a higher end cpu.
Protectli has up to quad core and up to 6 port nic. Each NIC port can be configured as needed…1 WAN 5 LAN, 2 WAN 4 LAN, etc and you can bond them too. It also supports AES-NI and yes, suricata supports multi core/thread performance. If I remember correctly, Snort does not. I prefer the r210ii because its using only about 30w it has 8 threads and support up to, I believe, 32GB ram which between suricata and pfblocker need the extra umph to maintain full gigabit throughput within intranet and internet.
I think I would go all out and get me a i7-8700T I hope it last me a while. 6core 12 threads. 16GB Ram, 64GB SSD.
Two more questions,
Do you know if pfSense support PoE LAN ports so I can connect the Ubiquiti access point directly to the computer where I would run pfSense.
And can you select the speed of the CPU?
As this one have a 2.4GHz base up to 4GHz.
