Nimbot backup, how?
Hi Tom been using the d110, nice quick labelling wherever you go :ok_hand:
All these labels I’ve got now grouped into customer folders, how do u back them up without giving a dubious company money for a VIP account?
Ta
Not something I have ever had a need to do, but my guess would be that you could find some app that backs up the settings of other apps assuming you can get the permissions to work.
After lifetime on android have moved to iOS…
Nimbot is listed in apps that are backing up to iCloud :slight_smile:
The same question has been on my mind. If Nimbot provided a straightforward local backup/export option without requiring a VIP subscription, that would be fantastic.
This is not something that I have tested but looks like a different way to solve the issue GitHub - MultiMote/niimblue: 🖨 NIIMBOT custom web client/app. Design and print labels with NIIMBOT printers directly from your PC or mobile web browser! · GitHub
tried iphone restor on my spare phone, did not bring over the templates
i think there is no way of backing up your templates without giving them your details
thanks for the github link, will setup a quick lxc container and see if it works when i access it over tailscale on my iphone browser that is paired with the d110…
