Hi everyone,
I’m encountering an issue with Nextcloud after upgrading my TrueNAS Scale instance to Dragonfish. My Nextcloud deployment consistently gets stuck in “Deploying” mode.
Background:
Prior to the upgrade, my previous Nextcloud instance (running for 1-2 years) functioned flawlessly using host paths as recommended in a video by Tom (details of the video unavailable).
To troubleshoot, I created a new Nextcloud instance (“nextcloud-2”) replicating the original configuration with the same host paths. However, nextcloud-2 also gets stuck in “Deploying.”
I was able to get a Nextcloud instance to run, but it was by setting all storage to iXVolumes, and I’m wanting to connect to the volume where I already have all of my user data.
Suspected Issue:
I suspect the problem might be related to using the same host path (“Nextcloud-Data”) for both AppData and User Data storage.
Questions:
- Could this shared host path be causing the deployment issue?
- If this is the issue, is there a recommended way to extract or copy the existing user data into a new dataset for a fresh Nextcloud installation?
Thank you in advance!
