Nextcloud install Problem on TrueNas
I just installed truenes and I tried to install nextcloud plugin and I get this after the install
Plugin installed successfully
Install Notes:
nginx_enable: → YES
mysql_enable: → YES
php_fpm_enable: → YES
Performing sanity check on nginx configuration:
Starting nginx.
Performing sanity check on php-fpm configuration:
Starting php_fpm.
Starting mysql.
Starting mysql.
ERROR 1064 (42000) at line 1: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘(‘JK8CPOK07YDS0gwe’) WHERE User=‘root’’ at line 1
Using NAT Address: 192.168.11.202
Error while trying to create admin user: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user ‘dbadmin’@‘localhost’ (using password: YES)
Trace: #0 /usr/local/www/nextcloud/lib/private/DB/ConnectionAdapter.php(69): OC\DB\Exceptions\DbalException::wrap()
#1 /usr/local/www/nextcloud/lib/private/DB/MySqlTools.php(60): OC\DB\ConnectionAdapter->executeQuery()
#2 /usr/local/www/nextcloud/lib/private/DB/MySqlTools.php(40): OC\DB\MySqlTools->isMariaDBWithLargePrefix()
#3 /usr/local/www/nextcloud/lib/private/Setup/MySQL.php(50): OC\DB\MySqlTools->supports4ByteCharset()
#4 /usr/local/www/nextcloud/lib/private/Setup.php(360): OC\Setup\MySQL->setupDatabase()
#5 /usr/local/www/nextcloud/core/Command/Maintenance/Install.php(108): OC\Setup->install()
#6 /usr/local/www/nextcloud/3rdparty/symfony/console/Command/Command.php(255): OC\Core\Command\Maintenance\Install->execute()
#7 /usr/local/www/nextcloud/3rdparty/symfony/console/Application.php(1009): Symfony\Component\Console\Command\Command->run()
#8 /usr/local/www/nextcloud/3rdparty/symfony/console/Application.php(273): Symfony\Component\Console\Application->doRunCommand()
#9 /usr/local/www/nextcloud/3rdparty/symfony/console/Application.php(149): Symfony\Component\Console\Application->doRun()
#10 /usr/local/www/nextcloud/lib/private/Console/Application.php(215): Symfony\Component\Console\Application->run()
#11 /usr/local/www/nextcloud/console.php(100): OC\Console\Application->run()
#12 /usr/local/www/nextcloud/occ(11): require_once(’/usr/local/www/…’)
#13 {main}
Previous: Doctrine\DBAL\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user ‘dbadmin’@‘localhost’ (using password: YES)
Trace: #0 /usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1486): OC\DB\Connection->connect()
#1 /usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1014): Doctrine\DBAL\Connection->getWrappedConnection()
#2 /usr/local/www/nextcloud/lib/private/DB/Connection.php(226): Doctrine\DBAL\Connection->executeQuery()
#3 /usr/local/www/nextcloud/lib/private/DB/ConnectionAdapter.php(66): OC\DB\Connection->executeQuery()
#4 /usr/local/www/nextcloud/lib/private/DB/MySqlTools.php(60): OC\DB\ConnectionAdapter->executeQuery()
#5 /usr/local/www/nextcloud/lib/private/DB/MySqlTools.php(40): OC\DB\MySqlTools->isMariaDBWithLargePrefix()
#6 /usr/local/www/nextcloud/lib/private/Setup/MySQL.php(50): OC\DB\MySqlTools->supports4ByteCharset()
#7 /usr/local/www/nextcloud/lib/private/Setup.php(360): OC\Setup\MySQL->setupDatabase()
#8 /usr/local/www/nextcloud/core/Command/Maintenance/Install.php(108): OC\Setup->install()
#9 /usr/local/www/nextcloud/3rdparty/symfony/console/Command/Command.php(255): OC\Core\Command\Maintenance\Install->execute()
#10 /usr/local/www/nextcloud/3rdparty/symfony/console/Application.php(1009): Symfony\Component\Console\Command\Command->run()
#11 /usr/local/www/nextcloud/3rdparty/symfony/console/Application.php(273): Symfony\Component\Console\Application->doRunCommand()
#12 /usr/local/www/nextcloud/3rdparty/symfony/console/Application.php(149): Symfony\Component\Console\Application->doRun()
#13 /usr/local/www/nextcloud/lib/private/Console/Application.php(215): Symfony\Component\Console\Application->run()
#14 /usr/local/www/nextcloud/console.php(100): OC\Console\Application->run()
#15 /usr/local/www/nextcloud/occ(11): require_once(’/usr/local/www/…’)
#16 {main}
Nextcloud is not installed - only a limited number of commands are available
There are no commands defined in the “config:system” namespace.
There are no commands defined in the “db” namespace.
Stopping php_fpm.
Waiting for PIDS: 24813.
Starting php_fpm.
Stopping nginx.
Waiting for PIDS: 24802, 24802.
Starting nginx.
Admin Portal:
http://192.168.11.122
is this right it dose not look right to me
after setting the jails I go to mange and I enter the info it asks but I get this and I can’t pass this step
please help
Been a while since I have used NextCloud, try the TrueNAS forums TrueNAS Community
When chasing these sorts of problems I usually start with the first error and work from there. In this case:
looks like you have a config error in the mysql config file, and given that the text given looks kinda like a password(?) perhaps the line didn’t get formatted correctly or a special character messed up the automatic file generation. Since the rest of the errors all look mysql related, that might be a good jumping off point.
That said, I used to run my OwnCloud server in a freeNAS jail (if that tells you anything about how long ago I did that). After a couple of years I got frustrated that the architecture of jails made it so that I couldn’t get what I felt were critical updates to any of the functional bits (because the jail is very tightly tied to the base freeBSD OS). I finally made the jump to using a VM on freeNAS, running straight-up Ubuntu server. Now I get all the OS and NextCloud (yeah, I made that jump eventually as well) as well as Apache and pHp updates in a timely manner. I will give you that this is a harder sell if you are in a highly RAM-constrained environment, but if you can bring your base system up to 24 or 32 GB of RAM, you should be able to make it work. As an added bonus, I was able to move all of my web hosts to that VM as well, so my website as well as a couple of dev and private sites are hosted off of the same VM with Apache virtual hosts handling all of the plumbing.
