Hi, I been trying to trouble shoot for a couple of days now and cant think anything else. Any comments/advice would be greatly appreciated!
Basic Network Setup
I’m running pfsense as my router and utilizing it’s HAProxy package to handle the ssl certs for my VM’s inside the network.
I am also using a managed port switch that connects downstream to a proxmox server. I configured it to be a trunk connection since I created vlan 100 to be for the proxmox web UI and vlan 150 for the VM’s
domain names are proxyed through cloudflare
The problem
I am able to obtain an ssl cert for whichever sub.domain.com, however, it takes a while to load and always results in error 522. The followings are what I confirmed:
- can reach servers through the direct ip address & port number combination, however, this is unencrypted
- HAProxy backend contains the correct ip address & port number
- HAProxy frontend is set with following settings:
- ssl-offloading enabled
- port = 443
- listening interface = wlan
- A record on cloudflare’s dns is pointing to correct public ip that router is facing
High Level Steps:
The following were my high level steps:
created a new HAProxy backend for vm
- used wildcard cert
- enabled “Encrypted (SSL)”
when creating new HAProxy frontend
- listening address = WAN
- ssl-offloading is enabled
- port = 443
- type = http/https
- ACL & Actions are set correctly
- certificate = wildcard
Firewall rules
wan
- pass tcp type from any source to any destination through 443
- changed the default pfsense https port to not conflict with HAProxy
vm lan
- block any type from reaching out to any other network
- block tcp from reaching to router’s new web ui port number
- allow any type from any source to any destination
Attemp for Local DNS Resolver
I then attempted to get a domain name to my proxmox server. I figured I can possible get it to work locally and not listen to the wan interface. This still resulted in a 522 error code for my desktop but resolves correcctly for my laptop. Still cant get it to work properly even when restarting the desktop.
High Level Steps:
created a new HAProxy backend for proxmox
- listening address = LAN
- port = 443
- type = http/https
finally, configured DNS Resolver and added Host Override.
- ip to return for host = gateway
Trouble shooting
- attempted to us
nslookupwithin pfSense by entering the IP address of the desired server and was able to resolve. Looks like it returned normally - used the following command and returns with the corrent domain,
openssl s_client -servername notes.example.com -host [PUBLIC-IP] -port 443 < /dev/null | grep subject=CN - used the command,
dig notes.example.com, it returns 2 A records that fall within cloudflares network so it appears to working correctly
