Many small rack cabinets cannot carry a 24-30 inch proprietary rail, even if the unit is within the depth of the cabinet. I am looking to find slide rails or shelf type universal rails that have a minimum length of 17" or less.
The only rails I have found are the Tripplite 4POSTRAILKITWM which is 14.5" minimum.
I havent found others. Do you know of sliding or fixed universal rails within this size specification?
