i have been playing around with PFSense for the past week now ever since I switched over from my ISP router, its now in bridge mode.
i have been setting up firewall rules. the first thing i wanted to do, again this is me just playing around, i wanted to block the PFSense Web Gui on all devices but the pc in the server room. the rule works great had to tick the box in advanced settings disable anti lock out rule for it work.
so then i thought why not block all other devices but the pc in server to access the unifi controller. so i went ahead and setup a rule “Pass” to the pc in server room and port. then created a rule to block all other devices to that ip and port. but it does not work.
My Friend told me its not going to work as the routing is bypassing the firewall. so my question is how do i get pfsense to use that rule for a machine to block another device raspberry pi hosting unifi controller so that machine cant land at the gui.
both devices are on the LAN, the rule is on the router under LAN, should i put the rule in WAN and see if that works ? is there a way for a rule or settting somewhere for rules to headout but noticed its internal and loop back hence passing through the firewall ?
Firewalls can not block device on the same subnet because they don’t pass through the firewall. This is why it can be a good idea to have a separate “Management SUBNET/LAN” that devices need to pass though the firewall rules to get to.
If you’re now using vlans, just create a management vlan stick your switches, AP on it. Block the other vlans from the firewall.
Move what you have on your LAN to a vlan.
That will give you what you are looking for. I don’t use my LAN unless I need to directly access the router for some reason say my switch stops working.
Keep in mind that the firewall blocks everything by default (except DHCP… if you enable the DHCP service on an interface it put’s in rules for that automatically which you cant easily find in the GUI). This means that if you want DNS to work you will need a rule. If you want to be able to ping stuff outside of the scope of that interface then you need a rule, etcetera. But do not forget that these rules are applied as packets transverse through pfSense (ingress and egress the scope of that interface) so you will still need a host based firewall to segment direct communications, or used host based isolation in Unifi to force everything through the firewall without exception. It’s important to properly segment the network but it doesn’t replace the other layers of security.
