Hi all,
We have 5x xcp-ng hypervisor, and 1x TrueNAS storage server and another Dell Equallogic storage server. The Hypervisors each have 2x 10G ports. We also have 2x 16 port Mikrotik switch to connect it all with. We cannot decide if it is better to bond the 2x ports in LACP mode with Mikrotik MLAG OR to use 1x port for storage connection and 1x port for normal traffic?
The advantage of bonding the 2 interfaces is that it offer a failover if 1 port goes down and separate traffic.
@LTS_Tom thank you for the reply. So then worse case scenario let say I have 1 interface down, as the host sahre the same storage, can I simply restart a VM on another host?
If I dedicate a dedicated network port to get the max bandwidth performance from the host, does it matter if the swich receive all traffic going through it (LAN + Storage)? I have a Mikrotik CRS317-1G-16S+RM. The storage network doesn’t have a dedicated switch. Will I still benefit for the performance of the dedicated interface in my scenario?
