I’m hopeful someone can make sense of these logs as im completely stumped now .
We have replaced all our networking equipment from Netgear to Unifi .
3/4 times per day our network drops for 15-20 seconds . We have recently replaced the firewall and i was hoping that would solve the issue but the issue still persists
I have pasted in the logs from the ProAggreation switch that is being used as the Top Level Top of rack switch , closest to firewall and servers etc . If anyone can spot anything in the logs i will be eternally grateful
May 14 14:09:13 ITCabinet4-ProAggregation1 user.info syslog: lcmd[1153]: lcmd.up date_uplink_port_id(): Reset uplink stat, uplink port 1 → port 29
May 14 14:12:42 ITCabinet4-ProAggregation1 daemon.info mcad: mcad[2850]: ace_rep orter.reporter_json(): immediately send user inform packet
May 14 14:12:55 ITCabinet4-ProAggregation1 daemon.info mcad: mcad[2850]: ace_rep orter.reporter_json(): immediately send user inform packet
May 14 14:13:11 ITCabinet4-ProAggregation1 user.notice syswrapper: [state is loc ked] skipping mca-send-inform
May 14 14:13:15 ITCabinet4-ProAggregation1 user.notice syswrapper: [state is loc ked] skipping mca-send-inform
May 14 14:13:19 ITCabinet4-ProAggregation1 user.notice syswrapper: [state is loc ked] skipping mca-send-inform
May 14 14:13:20 ITCabinet4-ProAggregation1 user.info syslog: mca-monitor[2968]: mca-monitor.do_monitor(): mcad.checkin is 17 ago (max=420)
May 14 14:13:23 ITCabinet4-ProAggregation1 user.notice syswrapper: [state is loc ked] skipping mca-send-inform
May 14 14:13:26 ITCabinet4-ProAggregation1 daemon.err mcad: mcad[2850]: ace_repo rter_trsp_curl.check_multi_info(): inform failed with curl code 28
May 14 14:13:26 ITCabinet4-ProAggregation1 daemon.err mcad: mcad[2850]: ace_repo rter.reporter_fail(): Timeout (http://192.168.170.240:8080/inform)
May 14 14:13:26 ITCabinet4-ProAggregation1 daemon.err mcad: mcad[2850]: ace_repo rter.reporter_fail(): inform failed #1 (last inform: 43 seconds ago), rc=4
May 14 14:13:26 ITCabinet4-ProAggregation1 daemon.info mcad: mcad[2850]: ace_rep orter.reporter_json(): immediately send user inform packet
May 14 14:13:31 ITCabinet4-ProAggregation1 user.notice syswrapper: [state is loc ked] skipping mca-send-inform
May 14 14:13:31 ITCabinet4-ProAggregation1 daemon.info mcad: mcad[2850]: ace_rep orter.reporter_json(): immediately send user inform packet
May 14 14:14:13 ITCabinet4-ProAggregation1 user.info syslog: lcmd[1153]: lcmd.up date_uplink_port_id(): Reset uplink stat, uplink port 29 → port 1
May 14 14:29:13 ITCabinet4-ProAggregation1 user.info syslog: lcmd[1153]: lcmd.up date_uplink_port_id(): Reset uplink stat, uplink port 1 → port 29
May 14 14:33:20 ITCabinet4-ProAggregation1 daemon.info mcad: mcad[2850]: ace_rep orter.reporter_handle_response_json(): cfgversion: 6985332837059632 → c4435b492 e4798c4
May 14 14:33:20 ITCabinet4-ProAggregation1 daemon.info mcad: mcad[2850]: ace_rep orter.reporter_save_config(): Saving stun_url as stun://192.168.170.240/
May 14 14:33:20 ITCabinet4-ProAggregation1 daemon.info mcad: mcad[2850]: ace_rep orter.reporter_save_config(): Saving mgmt_url as https://192.168.170.240:8443/ma nage/site/default
May 14 14:33:20 ITCabinet4-ProAggregation1 daemon.info mcad: mcad[2850]: ace_rep orter.reporter_handle_response_json(): [setparam] applying new system.cfg
May 14 14:33:22 ITCabinet4-ProAggregation1 user.notice syswrapper: [apply-config ] using fast apply
May 14 14:33:22 ITCabinet4-ProAggregation1 user.notice AxBpzmkTn: syslogd argume nts changed, sending SIGTERM to syslogd to force config reload
