Netgate SG2100 microSIM port
Hello, does anyone know if the microSIM port on the Netgate SG2100 can be used out-of-the-box or do I need to install extra hardware?
Thanks
There is no radio for LTE or 4G or 5G in any current Netgate product - you have to buy a card to add in to it.
Thank you. I have found in the Netgate website compatible 4G/5G USB antennas. Is there a similar list for internal M.2 ‘B’ radio modules or can I use any as long as it has compatibiity with the FreeBSD that PFSense is based on?
Not something I have ever tested.
