Hello
I got super hooked on XCP-NG after watching the Youtube stuff ! great content, very educational.
Im currently writing and experimenting with malware and are having issues getting nested virtualization to work wich is perfect for this !
My setup right now is XCP-NG baremetal installed making it my LVL0 hypervisor.
Via pool menu in XO i add a VM and installed XCP-NG again, but this time i checked nested virtualization under advanced. So far so good.
The issue is the following:
How do i get VMs on the nested LVL1 hypervisor, when i go to pool and create VM i can only select the baremetal hypervisor LVL 0. Under advanced theirs an option for start on but, i cant choose the lvl1 hypervisor it just allows me to install on the baremetal one.
Have i missed something or am i on the right path. My understanding is that i need to run the VMs inside the nested hypervisor LVL1 to get lvl 2 guests ?
The way I would set this up is not by double nesting. Just run a firewall, such as pfsense, virtually. From there the WAN on pfsense connects to your normal network and then you can connect a private network to your “Host Only” / GRE / VXLAN in XCP-NG. Then attach VM to that same “Host Only” / GRE / VXLAN which will put them together, but behind pfsense. You can control each VM’s ability to egress to the greater network from withing the virtual pfsense.
I will give that a try, thank you. Would you happen to know if i could put multiple VMS like so in Xen Orchestra ? Then allow for a vpn in on the network, i really like xen orchestra for training and wanna setup most of my labs within it.
Hi Tom
Sorry English is my second language. Thank you for your suggestion, i tried it and it works great for malware analysis.
I wasn’t clear enough in my second question, i apologies. My wish scenario in Xen orchestra is the following:
-I want to have a private network (vlan) only accessible with VPN connection to a VPN Server on that network
-no Host/VPN Server on that network or host connected to VPN Server is allowed to interact with my homelab/network.
-I’m unclear if this setup in Xen orchestra is possible, right now all my VMs are on the pool wide assc eth0 NIC except for the malware machines which is configured to what you suggested.
