The first raid 5 are sas 15k’s. So I’ll just go to ssd sata for the new raid 10 and move the hyper Vs there.
For backup I’m using SolarWinds and using a synology nas as the speed vault.
I might make the synology run a full hyper v backup as well.
Should I stick with Dell certified drives? Or can I just add some Samsung ssd drives?
Also, when I move the hyper Vs, should I use the export method?
Also, maybe I should add a Synology Nas and move all the file sharing data to it. What do you think?
I figure it helps with ransomeware protection and frees up a lot of space.
I think the Synology NAS can do snapshots as well as replicate to another NAS. Probably not a bad move to add a bit more resilience for ransomeware and file deletion.
Woops, yep 970s are NVMe only. I meant 860 Pros, I run some as OS disks and they report well in iDRAC.
I see 870 QVOs but no Pros, I’d avoid any EVO or QVO drives and only go Pro if you go the Samsung route. The TechSupplyDirect link I posted earlier has 800GB drives for $170 still with the caddy, which look cheaper than the 860 Pros.
I’m not too comfortable with refurbished, I don’t know.
So the Samsung pros show in Idraq? You mean the stats?
I put some Samsung evos in my person Dell server and they work but idraq won’t show lifespan etc.
