I am about to build my first NAS, and need to find a good motherboard for my build.
I’ve decided to use the Jonsbo N4 case, which limits my options to mATX and M-ITX boards.
My requirements are:
mATX or M-ITX
minimum 6x SATA ports
1x M.2 nvme slot
minimum 32GB max memory (preferably with ECC support)
at least one 2.5Gbps ethernet port, ideally 10Gbps
under 300 EUR
available in EU
I’ve been looking at a couple no-name boards with N100 and N355 chips, which seems like a good fit. But I have no idea about the quality and reliability of those.
Any recommendations or suggestions are very welcome!
Doing it again N150 would be a maybe, N355 might be higher priority. Anything with SFP+ instead of the 10g copper would have been worth some money, cost $50 more for a hot module to install in my switch.
