I upgraded my pfsense 2.7.2 CE edition to the latest pfsense plus edition.
I used to be able to access unifi protect from the web, unifi.ui.com, but now I cannot even though when I have remote access enabled. My plex external connection stopped working too. My VPN also shows “44B/s” traffic no matter how much I try and use the connection on android. I’m using OpenVPN instead of Wireguard. I don’t know if this started being an issue before the upgrade or not. I haven’t used these services in months. I setup them up using guides from Lawrence’s videos. I turned off snort and pfblocker in case they were somehow involved. That didn’t fix the issue. I should mention I am using a custom domain for DDNS and porkbun for DNS and Let’s Encrypt. That is updating my domain name to point to my public ip, which I believe is not behind CGNAT. I don’t know if Mediacom is somehow blocking ports on my for whatever reason, or if they moved me to a CGNAT without me noticing.
Checking the OpenVPN log on android it shows a connection via my username@domain.name 1195 via UDPv4 on tun/ 10.0.8.2/ gw=[10.0.8.1/] My network is setup with LAN being 192.168.1.0/24, WLAN being 192.168.2.0/24 and those entered into the routes in OpenVPN server on pfsense.
I will attach my firewall config. I did try restarting and clearing the firewall rules and starting over. I don’t know what to try and why I cannot connect to Unifi Protect through Unifi’s website. I get “slow” connection and it never loads, or now it says device offline, even though I can access my cloud key plus on my local network, but not over VPN or through unfi.ui.com.
Lastly, pfsense config uploads to netgate are failing and I keep getting a notification every 15 minutes or so.
