I just watched the video and it was awesome, one quick question.
I have a UDM Pro running the same version of Network 9.1.120 and under Control Plane =>Integrations I only have API listed. Activity Logging is displayed.
I do have Activity System Logging under System=>Traffic Logging.
Is this due to the difference in hardware? Thanks
The SIEM Activity Logging feature first showed up in version UniFi Network Application 8.5.6
but it does not list what models are supported. I don’t have a UDM pro to test, but it does show up in my UCG Fiber and UniFi Express models as well as my UDM Pro SE.
https://community.ui.com/releases/UniFi-Network-Application-8-5-6/bfa15dd8-8b58-4d40-9d83-73ebe8c9a955
Make sure you are using the newer Zone Based Firewalls as that might be required now as well.
Thanks Tom, I am using ZBF and I did see there is a console upgrade going in this Sunday for me, I’ll check it after the update. Appreciated as always!
Just an FYI, after the firmware update the settings showed up for me.
