Migrating from Untangle NGFW to pfSense
Hi everyone,
I chose to post here rather than in the pfSense forum as when I looked at the multiwan section is pretty quiet and almost no one replies to questions there. As with almost all other Untangle/Arista home users, I’m on the hunt for a replacement routing platform.
My situation: 2x 1Gb fiber WAN (“main” Untangle router) + 2nd Untangle router upstream for 3x Starlink residencial services for backup. I live outside the US so fiber interruptions are almost 25x/year at 6h to 3d of outage. FO installs are also scarce, so I share my connections to 6 other neighbors. Switching to Starlink used to be uneventful, but with more SL subscribers in our area, SL seems to bottleneck now.
What I love about pfSense:
  1. Gateway groups- this should make WAN failover to SL more effective as with Untangle, I have to set up a two-router system to failover to multiple Starlink services.
  2. HFSC QOS. Untangle uses fq-codel and while I don’t know for sure yet (haven’t tested it yet), I’m hopeful that with the ability to monitor queues that I can tune the QOS so that my 12 neighbors and I can share Starlink bandwidth more effectively. Of course when we have FO, bandwidth isn’t a problem.
What I’d love some input on:
  1. Any way to monitor WAN failover. Untangle has stunning graphing capabilities that enable me to see at a glance where the WAN issues are. I’m not a CL person, so Grafana is going to be a steep learning curve. I would be happy to pay someone for help however!
  2. Using HFSC to throttle streaming services (YouTube/Netflex/Tiktok et al) when the network fails over to Starlink. I think I might be able to do that with floating rules in the FW, but I haven’t gotten that far year in my learning. In Untangle, configuring QOS is a layer 7 dream, but not so much in pfSense.
  3. Blocking certain applications (social media/youtube etc) at certain times of day. I will sorely miss Untangle in this aspect, but if pfSense “just works” in the more critical areas of WAN failover and QOS than this might be a trade-off that I have to accept.
Thanks in advance for your thoughts.
This might be what you are looking for, you can monitor the status of each WAN in pfsense with the built in tools, I have a video on that here:
It’s true that pfsense does not have good Layer 7 rules.
Thanks Tom! Thanks for all the work you’ve put into your content.
