This might get ranty but I’m losing my mind here. I have a local wireguard VPN that I use to connect from my worksite to my home on my laptop and everything typically runs fine. I can access my resources and take advantage of my pihole.
The company sent me on a work trip in another country. I connect to wireguard and try to access my local resources and no luck. I can access my pfsense via its IP address/port but not by dns name. I thought ok well let me check my other resources via direct IP and I get nothing. Here are some further troubleshooting steps I’ve taken:
- ping other servers on the same vlan via their IP: failed
- ping other vlan gateways by IP: passed
- restarted pc and pfsense and tried the servers on the same vlan again: failed
- changed the wireguard config from AllowedIPs from 0.0.0.0 to add the subnets of the servers with a /24: failed
- Checked firewall logs with nothing specifically being blocked that I can see.
I had an ovpn server Ive left running that I’ve used before switching to wireguard, and I’ve done the exact same troubleshooting steps.
I tested my wireguard config before leaving the house and I have a brand new laptop that I set up wireguard on and tested with no issue.
Any ideas on where to start looking would be great.
