Now that more folks are reviewing the new Zone based firewall in the UDM has anyone been looking at how the logging looks when sending the firewall rule events to Graylog. Under pfSense I have built some very good dashboards for their firewall rules and looking to do the same with the UDM thanks to Tom’s excelent Graylog YouTube video.
At some point I will build some new Graylog import parcers, unless someone get’s that done before I do and shares them.
I would love to see how you have graylog setup with your zone based firewall rules.
As stated in my other post, pre ZBF, graylog was awesome and caught everything. Now that I upgraded, i only get triggers. I’m wondering if the setup in graylog has to change too.
Nope, you just have to put the Graylog IP in the SIEM settings and check all the boxes.
That’s what I figured, I’ve had it setup for over a year with pre zone based firewall rules and it worked great. I cant get anything meaningful from my firewall rules since the upgrade.
There is a lot of data, just not the detail behind the blocks. I only get the same trigger info that’s in the udm gui so its not too helpful since it lacks the source/destination port info.
I finally got some time off to start working on UDM logging into Graylog and I have set the SEIM server both in the control plane integration and cybersecure traffic logging. Both services are posting messages in graylog but I am not seeing any firewall events. In pfSense I had both blocked and allow logged but nothing I can see will send the forwarded and blocked firewall events. I think I am missing something from the YouTube vid you published 3 weeks ago.
In version 9.2 go to “Cybersecure” then “Traffic Logging” and make sure under contents for the SIEM server you have “Firewall Default Policy” checked. I also think you need to be using the new zone based firewall rules.
