Locked out of pfsense
Just walked through your video for:
How To Create pfsense Let’s Encrypt Wildcard Certificates using HAProxy
My FreeNAS box now has a valid cert and can only be accessed from within my home lan. YAY!!
BUT,
Now I can’t access pfsense on my SG1100. Here are some screen shots:
Screenshot from 2020-03-15 23-07-22
Have I completely hosed myself? Suggestions?
Thanks,
-Willie
Did HTTPS work before? Try http://192.168.3.1. If that doesn’t work, I would reboot it.
did you change your port, try https://192.168.3.1:443 or http://192.168.3.1:80
Yes HTTPS did work before. I ended up accessing via usb console and choosing option 15 to roll back to the last working configuration. After a reboot I can now access pfsense again. Now I just need to figure out what was causing the problem.
Thanks for the suggestions.
