Hi All,
I have a HP PC running ubuntu 20.10 with OBS installed.
Connected via USB I have a Logitech Webcam, a Blue Yetti Microphone, Cheap action cam and a HDMI capture device. I also have a wireless keyboard and mouse combo but I think that’s out of scope.
When I start OBS it seems that I only get either the actioncam OR the HDMI capture but not both. When I open the video capture (v4L2) source and check the device dropdown I only see the Webcam and one of them. I am fairly sure that it only shows the most recently connected device (so unplugging and re-plugging makes it switch).
If I unplug and re-plug things then sometimes I do manage to get both working at the same time but more by luck than judgement I fear.
Does anyone have any idea what’s going on or suggestions for ways to start working this out? I guess a starting place might be something else that is capable of looking for and opening USB video input devices might be a start to rule out an OBS issue but I’m not really sure what to look for.
In case it helps any if I lsubs I get;
Bus 002 Device 004: ID 1bcf:2c99 Sunplus Innovation Technology Inc. FHD Capture
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 046d:c52e Logitech, Inc. MK260 Wireless Combo Receiver
Bus 001 Device 003: ID b58e:9e84 Blue Microphones Yeti Stereo Microphone
Bus 001 Device 010: ID 1b3f:2002 Generalplus Technology Inc. 808 Camera
Bus 001 Device 005: ID 046d:082d Logitech, Inc. HD Pro Webcam C920
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
each time I unplug and replug the device 00x number goes up by 2 for the Generalplus actioncam and by 1 for the Sunplus (which is the HDMI Cap)
