Like for Like swap of router
I want to do a like for like swap out of an araknis an-110-rt-2L1W router. The current one is failing regularly. Can i simply unplug the current failing router and plug in the replacement? Any else i need to do? Thank you for any help.
I have never used anything by Araknis but assuming you export the configuration from the old one and import it into the new one it should work.
You could also restore a backup if you had those.
