I have a cheap label maker. I haven’t used it in a while because the tape peals off after some time. I decided to try heat shrinking it in place for some extra durability.
It’s a thermal printer. Now the label looks horrible.
Does anyone have a recommendation for a non thermal label maker?
No issues with labels fading (nothing exposed to light or high heat) but the adhesive does degrade a little, still no labels falling off. If you stick a label to say a wall jack, then cut the clear portion and layer it over the top of the label, it last pretty well since no air can get to the printed part. Light fading will be reduced when applied this way as well. They used to have an ink based wrap around label system, but I haven’t seen it in a long time.
I’ve had decent to poor luck with this system, a lot of it has to do with having fresh tape when you start a project, and cleaning the surface really well to remove dirt and oils. Cleaning with alcohol normally gets me about 5 years between replacements. I’m especially partial to the white on clear for dark colored equipment, this has held up really well for me.
Thanks,
I am labeling the end of cables.
I thought I was being smart slipping a piece of heat shrink over the cable before I put the ends on. When I heated the tubing up the lable turned black. The tape is the Brother M tape.
I’ll have a look at the links you you sent. I was actually looking at the DYMO one you posted. Price is right I just want to confirm I can use it under heat shrink.
You can get those Brady label printers pretty cheap on ebay. For cables I would not use the Dymo, they have a cable program but that uses the flag method and flags always get pulled off.
You can uses get wrap around cable labels that get run through a laser printer, if you have a big job and need a pile of labels, that’s the best way. The Brady is good for medium and small jobs printing onsite. Here is an example from a company that I’ve used before:
The adhesive tends to get gummy after 5 to 10 years and a pain to remove if you need to update or change a label, but they hold pretty good. I’ve also used the type that you write on with a permanent pen, same adhesive just flexible since you write on it. The ink pen can smear a little after many years.
The only issue I have is the (3/4", max supported size) self-laminating labels are too small to wrap around Ethernet or coax cable. They will work on my Monoprice SlimRun cables, though.
the 1 is good for Cat5 and slim cables, we also use it on audio and slim video cables. The 1.5 works on Cat6a and the old Belden GX10 as well as RG59 size video cables. Looks like the 1.5 is the biggest label that fits these.
I wish these systems would print closer to the edges, they always have huge margins and waste a lot of tape.
