Not sure what caused it, but randomly one afternoon, my pfSense decided to stop assigning IP addresses to computers joining the network. The TVs were still online, as were my servers, but phones, and PCs which were trying to access the WiFi got no love. Had been working fine for 1/2 a year, but I found this in the DHCP logs.
| Aug 31 13:45:49 | kea-dhcp4 | 56784 | WARN [kea-dhcp4.alloc-engine.0x27dbcc816600] ALLOC_ENGINE_V4_ALLOC_FAIL_CLASSES [hwtype=1 34:cf:f6:2b:7c:3a], cid=[01:34:cf:f6:2b:7c:3a], tid=0x3cbc5590: Failed to allocate an IPv4 address for client with classes: ALL, VENDOR_CLASS_MSFT 5.0, pool_lan_0, UNKNOWN |
| Aug 31 13:45:49 | kea-dhcp4 | 56784 | WARN [kea-dhcp4.alloc-engine.0x27dbcc816600] ALLOC_ENGINE_V4_ALLOC_FAIL [hwtype=1 34:cf:f6:2b:7c:3a], cid=[01:34:cf:f6:2b:7c:3a], tid=0x3cbc5590: failed to allocate an IPv4 address after 45 attempt(s) |
| Aug 31 13:45:49 | kea-dhcp4 | 56784 | WARN [kea-dhcp4.alloc-engine.0x27dbcc816600] ALLOC_ENGINE_V4_ALLOC_FAIL_SUBNET [hwtype=1 34:cf:f6:2b:7c:3a], cid=[01:34:cf:f6:2b:7c:3a], tid=0x3cbc5590: failed to allocate an IPv4 lease in the subnet 192.168.1.0/24, subnet-id 1, shared network (none) |
| Aug 31 13:45:34 | kea-dhcp4 | 56784 | WARN [kea-dhcp4.alloc-engine.0x27dbcc816600] ALLOC_ENGINE_V4_ALLOC_FAIL_CLASSES [hwtype=1 34:cf:f6:2b:7c:3a], cid=[01:34:cf:f6:2b:7c:3a], tid=0x3cbc5590: Failed to allocate an IPv4 address for client with classes: ALL, VENDOR_CLASS_MSFT 5.0, pool_lan_0, UNKNOWN |
| Aug 31 13:45:34 | kea-dhcp4 | 56784 | WARN [kea-dhcp4.alloc-engine.0x27dbcc816600] ALLOC_ENGINE_V4_ALLOC_FAIL [hwtype=1 34:cf:f6:2b:7c:3a], cid=[01:34:cf:f6:2b:7c:3a], tid=0x3cbc5590: failed to allocate an IPv4 address after 45 attempt(s) |
| Aug 31 13:45:34 | kea-dhcp4 | 56784 | WARN [kea-dhcp4.alloc-engine.0x27dbcc816600] ALLOC_ENGINE_V4_ALLOC_FAIL_SUBNET [hwtype=1 34:cf:f6:2b:7c:3a], cid=[01:34:cf:f6:2b:7c:3a], tid=0x3cbc5590: failed to allocate an IPv4 lease in the subnet 192.168.1.0/24, subnet-id 1, shared network (none) |
| Aug 31 13:45:25 | kea-dhcp4 | 56784 | WARN [kea-dhcp4.alloc-engine.0x27dbcc816600] ALLOC_ENGINE_V4_ALLOC_FAIL_CLASSES [hwtype=1 34:cf:f6:2b:7c:3a], cid=[01:34:cf:f6:2b:7c:3a], tid=0x3cbc5590: Failed to allocate an IPv4 address for client with classes: ALL, VENDOR_CLASS_MSFT 5.0, pool_lan_0, UNKNOWN |
| Aug 31 13:45:25 | kea-dhcp4 | 56784 | WARN [kea-dhcp4.alloc-engine.0x27dbcc816600] ALLOC_ENGINE_V4_ALLOC_FAIL [hwtype=1 34:cf:f6:2b:7c:3a], cid=[01:34:cf:f6:2b:7c:3a], tid=0x3cbc5590: failed to allocate an IPv4 address after 45 attempt(s) |
I had seen
in the Advanced Options, and thinking EOL = bad, and it seemed like sooner or later I needed to use Kea, I just switched to Kea months ago. Worked fine until today, power cycles, updates, nothing helped my network until I ticked back to ISC DHCP.
Actually reading about the two versions of DHCP, sounds like while Kea is the new cool standard, many are staying with ISC, because it ain’t broke. Just a curious battle I came home to one evening.
