KEA DHCP and DHCP Option 43
I’m on pfSense 2.8.1 and tried doing the DHCP Option 43 for Unifi adoption. But I’m using Kea DHCP and the ISC DHCP isn’t available anymore to switch back. Has a workaround been figured out or do we have to wait for Netgate to add the “Custom DHCP Option”?
Edit: Got some help from AI using JSON as follows…
We have it working, you need to enter the details in two places
Under Services - DHCP Server - Settings - Custom Configuation
“option-def”: [
“space”: “dhcp4”,
“name”: “unificontroller”,
“code”: 43,
“type”: “binary”
Under Services - DHCP Server - Select the Network - Custom Configuration
“option-data”: [
“data”: “0104xxxxxxxx”
Data has the ip address of your unifi controller 0104 hex value of server
Hello, sorry to say but it’s not working!
I think because it say’s below the JSON input veld:
*JSON to be merged into the “subnet” section of the generated Kea DHCPv4 configuration.
The input must be a well formed JSON object and should not include the “subnet” key itself.
and also the JSON is not recognized ass valid json format.
The following input errors were detected:
  • Custom configuration is not a well formed JSON object.
:frowning:
It didn’t work because of the quotes. Copy and paste these instead.
  "option-def": [
      "code": 43,
      "name": "unificontroller",
      "space": "dhcp4",
      "type": "binary"
  "option-data": [
      "data": "0104xxxxxxxx",
Thank for JohnF350KR and pjsayers.anotherit also xMAXIMUSx it works now fine.
I did the same as example by xMAXIMUSx and it works like a flawless
Alway keep my fingers crossed :slight_smile:
