However, I am unable to install packages from the GUI. If I bring up ‘Available Packages’ and click ‘Install’ I am thrown back to the ‘Installed Packages’.
So I resorted to command line. I Successfully installed specific packages without a problem.
However, the installed packages do not show in the GUI in ‘Installed Packages’ and they also do not appear in the pfsense menu??
For example I installed pFBlocker. pFBlocker is not showing as an installed package and there is not GUI Option to configure pfBlocker?
Anyone come across this issue before please that could offer advice or help?
If you happened to have saved the previous pfsense ISO you could try installing that and then upgrading to the latest version. Netgate post their latest ISO only.
I’ve upgraded and don’t have any problems with the packages.
If you weren’t aware you can easily backup your config so you don’t lose any work you’ve already done.
