Took the plunge and updated to R.13 last night. Two of the jails have issues now.
If i run wget in one jail, I get the error message:
ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/bin/wget not found
In another jail, the newly upgraded Thunderbird (upgraded automatically during the jail upgrade) fail with the same complaint about libc.
But libc is definitely there:
$ file /lib/libc.so.7/lib/libc.so.7: ELF 64-bit LSB shared object, x86-64,
version 1 (FreeBSD), dynamically linked, for FreeBSD 13.0 (1300139),
stripped
I tried to remove and reinstall both wget and Thunderbird, but that didn’t solve the issue.
I found Thunderbird 91.1.3 in pkg cache, removed Thunderbird and installed the cached version. Now I can start Thunderbird again.
I also tried to force reinstall all libraries. That didn’t resolve the issue either.
Anyone know how to fix this issue?
