Issues setting up network
Hi everyone I’m new to the forum and hope this post is in the right category, I have followed Lawerence Systems on youtube for several years and have learned much from them.
I’m having an issue that I hope someone on the forum has seen and can give me a hand with.
My setup is: I have Spectrum Business class with 5 static ip’s mainly because thats all I can get in my area.
So I set up the first of my 5 ip’s connected to my PFsence router and run a web and mail server on that ip.
I would like to setup another of my ip’s on another of my PFsence router’s for my work stations, but when I test this setup
I can get out to the internet but I can’t get to my webserver control panel, or see any of ther websites running on the server or get e-mail.
From my home Spectrum network I can get to the webserver and e-mail.
It is like the two ip’s will not talk to each other.
My network from Spectrum ip’s x.x.x.154 - x.x.x.158 gate x.x.x.153 mask x.x.x.248
I setup the first PFsence box with x.x.x.154 gate x.x.x.153 mask x.x.x.248 and DNS servers Spectrum whats me to use.
Secound PFsence box the same way but with the ip x.x.x.155
I’m fairly new to networking and would appreciate any help or guidance. Thank you all in advance.
Ok so you are running this in HA from what I am reading. What was the VIP you set?
This is also a good read if you haven’t read it already.
I just set it up with the wan ip as my first static x.x.x.154 with my gate x.x.x.153 and mask x.x.x.248, and then setpup my LAN ip’s I will take a look at the document you sent me thank you.
Why are you trying to use two pfsense firewalls.
Your workstations put in a vlan network which does not have access to any other internal networks.
With PFSense under Firewall - Nat - Outbound, you can say your workstation network goes out on .155 wan address
yes I tried that but but same issue, I can get to the internet on those workstations but still can’t get to the server or e-mail coming from server on .154.
