Issue with 2 tailscale enabled side with mobile devices
Hey all,
I’m having trouble with Tailscale on my mobile device when trying to connect to a LAN network between two sides (let’s call them Side A and Side B).
I have 3 machine on Tailscale admin console,
-Side A pfSense router with subnet(192.168.10.0/24) expose.
-Side B pfSense router with subnet(192.168.20.0/24) expose.
-Mobile devices
Scenario 1
Mobile device connected to Tailscale VPN on cellular network I’m able to connect to both Side A and Side B local network no problem at all.
Scenario 2
Mobile device connected to Side A wifi that has Tailscale already enabled, & with Tailscale App VPN enabled. I’m able to access Side A local network & Internet no issue, but unable to connect to Side B local network. Same with Side B connection
My workaround currently
1.When I arrived at Side A or Side B, I manually disable Tailscale App VPN.
2.Disable Wifi on mobile device and connect to carriers cellular network with Tailscale App VPN enabled.
Asking for solutions without above workaround.
I’m suspect it was NAT issue, but unable to confirm.
Has anyone else experienced similar issue? If so, what solutions or workarounds have worked for you?
Any advice or suggestions would be really appreciated!
Thanks in advance!
