ISP changed IPv4 address and DHCP Server IP address, pfsense required manual intervention
pfsense 2.8.1.
Last night my ISP changed my WAN IP network and the DHCP Server. In the Pfsense logs I see the following:
High Latency on reported by dpinger for the old default gateway. I see that the DHCPREQUEST where sent to the old DHCP Server and they failed with a “no route to host” error. I rebooted the cable modem and with the Wan interface going down a DHCPREQUEST was sent to the broadcast IP address. I new DHCP server addresses responded and the lease was granted for a new IP address.
My questions is why wouldn’t the DHCP process, at some point, tried a broadcast to discover the new dhcp server?
Is there anything I can do to prevent this outage in the future?
thanks
I don’t think this was a pfsense issue. Sounds like your ISP had something happened and your modem was hung up.
possible and no way to recreate. In hindsight I wish I had worked on the WAN dhcp side before rebooting the CM. I just would have thought DHCP would be more aggressive to try and recover….
