We have been testing/using Ninja Remote and curious if anyone else is experiencing this behaviour.
Administration > Apps, NinjaOne Remote: Enabled
Administration > Organization > Ninja Remote, General: Disable integration
It appears when the NinjaOne Remote “App” is enabled, it is enabled accross ALL Organizations regardless of the Org integration setting.
Test by going to a Disabled Organization in the Dashboard:
From the Overview list “hover” the mouse over a system and click on the triangle that appears. In the drop-down menu you will see the “Ninja Remote” option. Select that.
Surprisingly … Ninja Remote client will connect!
Is it a concern that the remote tool integration is installed and active on Organizations that are explicitly set to Disabled?
We do have an open request with NinjaOne since June 2024.
